Agreed Joe, fingers crossed she surveys well today!
good luck with your survey. I wanted to remind you that there should be some extra equipment if the mast is intended to be lowered completely... i.e. so it can be removed or worked on. Some kind of gin pole device, or other method of raising the lifting control line ABOVE the hinge point (mast step). Once the mast gets close to parallel, the lifting line has insufficient angle to pull up on the mast. If you're just dropping the mast to 45 degrees or so then any point at cockpit level, a halyard winch on the cabin top for instance, would give plenty of angle. My Nacra 5.2 had a 26 ft mast, the base was a ball/socket device that allowed spar to rotate, and also lower. That system, the mast dropped aft. So the trailer had a tower with a block near the top which was used to get the winch line up above the level of the mast base. At the rear, I had a tripod like pedestal that was positioned to "catch" the mast, and keep it from dropping below horizontal. (lots of guys used a 6 foot folding ladder for the same purpose) My 3 legged device folded so it could be stored easily on the trailer or in the cat box.
The reason I'm blathering on like this is to suggest that there can be more than one way to get the mast down safely, A gin pole, a tower, a ladder, etc what you need to understand is the geometry. Figure that out and you'll have a nice picture.
