RF connection for GPS/Wind transducer cable instal
107
Beneteau Oceanis Boca Raton, FL
I just installed a Raymarine A65 GPS Chartplotter. I have it working, but did not know what to connect the RF (shilded wire) to. The instructions were not clear on the point. Have tried to find on Raymarine site. Guess I just have not found the right keywords to locate. Any experts on connecting this wire? Also planning on buying a wind system. The transducer will have to run inside the mast. The current exit holes at the mast base are about the size of the cable. Will be replacing an old transducer. Any suggestions on how to get the cable down the mast and out the hole?
Jun 6, 2006
6,990
www.raymarine.com
Google.com raymarine The shield should go to the metal part that surounds the port you are connecting to or the metal case of the box your are connecting to or if the case is plastic the circut board ground, or as a last option, the boat ground via the box you are connecting to. The last option is not a great idea but better than nothing. The shield protects you from stray interferance sooooo if you have a quiet boat you don't even need it. Unfortunatly most of us have our boats loaded with radars, gensets, alternators and the like and absolutly need the shield. Most mast connections are "under" the mast so you can unstep the mast and not have to cut the wires. Even if you don't take the mast down very often this is a good idea just make sure the connector is waterproofed before you instal the mast. Cables are interesting as they have two ends. If you can disconnect the top end and attach a line then you only need to make two trips up the mast. Otherwise you will need to either drop a stiff wire down the mast or unstep it and fish a wire through it. Either way is a lot of work but I'd opt for two trips up the mast. Dont forget to check the bow light, spreaders and mast head while your there.
