Rewiring of Hunter 33.5
1
- - Lake Lanier, Atlanta, Georgia
Hello all: Bought my boat about 4 years ago. It was a salvage situation. Electrical and electronics (most of them) got fried when boat was being moved out of the marina and Travelift passed closed to High Voltage Lines...I been procrastinating...New wires are all good thru the mast...but I never connected them to the panel...very hard to feed the wires thru the old boat...also the navigation lights are out and their cables really burned...so I cannot use the old wired to pull thru the new ones.. Any one can suggest a tool or technique to help on my situation?? All help will be surely appreciated.. Daniel Suenio de Pibe - Lake Lanier, Atlanta
Mike Sullivan
I am doing some of the same
It's called a "fishtape". Should be available in 25', 50' 100', etc. It is commonly used by electricians for running wire through conduit, or other places they cannot reach. Readily available at hardware stores at modest prices. Basically, it is a coil of thin spring steel fed from a spool designed to contain it and retrieve it. Good luck, mIke
