Hello MaineSail - I appreciate all your advice, hope you have a minute to weigh in on this question -
I'm about to rewire my Catalina 28 harness to eliminate the old plugs that had some fire issues, while at it I'll add the engine circuit breaker and starter solenoid.
The replacement harness calls for terminal strips at each end with the harness connecting between the strips.
There is enough slack to wire directly from the engine to the panel, eliminating the terminal strip at each end for fewer connections that may in time loosen or fail.
Are the terminal strips required, is there an advantage to eliminating ( or keeping) them?
