rewiring 30 mast
Good luck. Not impossible put it was a chore. I have an older 30 and the material used to muffle the coax inside the mast was nothing but foam rubber loaded with a wad of (u guessed it) duct tape. Well when I went to pull the old anchor light wire out it would not come. My best guess is that it was saftied to something near or around the spreaders. Mind you I doing this on the ground. Anyhow, I had a hell of a time getting it right and all it was, was a common sense test. I gotta go duh on that one, all other wiring went off without a hitch except for the masthead.
