reverse gear
40
macgregor 26M Macgregor 26M newcastle
Just bought a 1982 Catalina 30 with 30 hp gas engine. Have trouble getting tranny into reverse. Won't go into gear unless I really crank it. Then, when in gear it really handles like a pig. Is this normal ?
Gear shift lever on engine and cable to binnacle.
Prop walk if you have to steer to the right under power. Otherwise, check steering quadrant if you have a wheel.
cat30
Jun 2, 2004
51
Island Packet 31 stony point,ny
Reverse gear on atomic 4 does not have positive detent so it seems like it isnt in gear- then you have to rev it up cause it is 2-1 gear ratio in reverse (i believe) so it really starts to whine when in reverse. when you hear it whining you should be going backwards.
Aug 12, 2010
40
exactly what happened today. trick is to give more throttle despite the whining noise. Thanks again
