retrofit mast tabernacle
Mike Frampton
Is it prudent to retrofit a mast tabernacle to a daysailor 2? Have recently purchased a 77 DS2 and am concerned with the effort involved for one person installing the mast thru the cuddy. I sail solo and would this make rigging the boat alone easier? Are the Tabernacles still available for this mast, if so, where would I look to obtain one. Any input would be appreciated.
Trevor - SailboatOwners.com
I don't see why not
Hi Mike - I don't have personal experience with your boat, but I don't see why you couldn't retrofit a mast tabernacle to your daysailor 2. Try contacting Rudy at D and R Marine at 508-644-3001; he might have some good information for you. Best, Trevor
Jack Easley
Mike. I used some stainless tabernacle "hinge plates" and fixed them to my mast, after cutting it at the proper place just above the deck line. This was to prevent the awkward practice of getting the mast thru the deck and down into the partner in the keel. This worked fine, until I got in a 30+ blow, and the whole thing came apart! The purists will say don't cut your mast, and, for many other reasons, I would agree. But, if you can find an old mast, or if you do cut yours, be sure to 'beef' it up in case you get in a blow. Great Sails to you, Jack. capn_jack@msn.com
Rod Johnson,
D&R Marine Does have
Rudy at D&R Marine does sell a tabernacle kit for the Day Sailer (I or II), If done correctly the mast will be just a strong. However, it will no longer stay up without the shrouds and forestay attached. This is no problem, since actually once installed, a tabernacle allows you to leave the shrouds attached to the chainplates all the time, when trailering all you need to release is the forestay. Rudy sends out the original O'Day installation instructions with the tabernacle (mast hinge) kit. You could also have a local sparmaker do the installation.
Mike Frampton
Will this make rigging easier?
Will the tabernacle make rigging by one person easier? or is it still a problem after the mast is erect, getting the forestay attached with out dropping or twisting the mast?
Rod Johnson,
Should be easier.
It depends on a few things, but having helped someone step the mast on a Day Sailer I that had the tabernacle, I'd say..DEFINITELY easier. The advantage of the hinge is that as you pivot the mast up, the shrouds will provide some guidance as the mast reaches vertical. If I were stepping the mast all alone, what I'd do is to tie a line to a bow cleat (or the trailer if the boat was still on trailer), make it long enough so that the shackle on the jib halyard can be connected to the line. Now, as you raise the mast, take up the slack in the jib halyard. Once the mast is vertical, tie off the halyard to hold the mast up, try to get it real tight. Now, just attach the forestay, insert the forawrd pin into the hinge, and ease the jib halyard. Reverse process to unstep mast. O'day (in the installation instructions for the tabernacle) says to raise the mast and insert the forward pin into the hinge and then attach forestay. I would think that should work, just don't leave it too long before attaching the forestay. Personally, I'd still use the halyard as back-up.
