P
Peter
I wonder if anyone else has trouble pulling their H 18.5 out of the water? Mine is very difficult to get centered correctly on the trailer I have. The supports are two 8' 2X4's and it is very difficult to get the boat centered correctly over those with the result that virtually every time I have tried to pull the boat out of the water she is over to one side and I am scared to death that she will fall off the trailer onto her side. I have a couple of ideas for centering her, one being to get trailer guides, but she is far over the 6" allowed by most trailer guides for side movement. I could try these, but doubt that they will work because of that. She is, centered over the trailer, far in excess of the six inches that the trailer guides I've seen allow on each side. The other possibility is to put 2X6 boards on the bottom of the trailer to guide the keel into the center of the trailer. These I've come up with -- does anyone else have other ideas?? Every time I have taken this boat out of the water I have had trouble centering her on the trailer. Two 8' 2X4s don't seem like enough support, but that's what the trailer has. Those of you owning H18.5s, is your trailer similar to mine? I'm not even 100% certain that the trailer is the correct one for the boat. Any ideas will be very much appreciated. Thanks, Peter S/V Katy Kaye
