Answers to questions...
Thank you guys for all o fyour great feedback and assistance.Here are my answers:Q1 When you engage the thumb 'knob' by sliding it down the lever, does it make contact with the pawls? If the pawls are the brass teeth, then yes, it actually moves pretty freely up and down the lever shaft.Q2 If it makes contact with and engages the pawls, does rolling if off the boat, lift the 'knob/lever' and disengage the mechanism? It sounds as if you are thinking that the 'brass teeth' move, and therefore lower the CB. The 'brass teeth' only serve to lock the lever in place, either up or down, essentially creating a multi-position CB for different depths.Q3 If it does not make contact with or engage the pawls, you may have slid the knob on 180 from its original orientation. There are actually 'knobs' on either side of the handle, but as I learned the first time I removed it, it only fits on one way.does the lever move when the CB contacts the roller when launching the boat? It used to, now I'm not sure. I think it wiggles back-and-forth sideways a bit.Or is the lever free of any load, all the time? I can now move the lever, while sitting in the trailer, all the way up and down with no effect on the CB.At launch, the slide tab on the lever has to engage the highest pawl. Fred, you knew that, right? I always keep it there, however, even with it furthest 'forward', the CB still drops freely once there isn't a roller holding it up inside the trunk.Do you know if it was working properly when you first got the boat before taking the mechanism apart? Yes, the first time I launched the boat, it worked properly. Somewhere along the way my meddling and tinkering for educational purposes caused it to no longer function.JB I think you might have hit the nail on the head. It sounds like whatever mechanism causes the forward and aft motion of the lever to make the centerboard go up and down is not working.I will disassemble it this evening (east coast) and see if (hopefully) there is some sort of pin or key that I can access without tearing open the trunk.If I have to get inside the trunk to fix the problem, it'll just have to stay that way ;-)Thanks again guys! I'll post pics of the disassembly tonight if you are interested.Fred A.
