On the East coast of Fla.
Is the gulf stream. Add the speed of the boat to the speed of the current and you can make some time. The hull speed is moving thru water that is not moving add in the current and wow.If you have a tide, or coastal stream, the speed over the ground will change. Wave motion could play a role. However, the Knot meter should read near the hull speed.The hull speed formula 1.34 time the square root of the waterline line length is the same for the speed of waves. If you measure the length between two peaks of a wave you can calculate it's speed with the same formula.My thought is that you are in waves with large peak to peak lengths. These waves are actually carring you because of thier speed. The thing that puzzels me is that the GPS and the knot meter read the same.r.w.landau
