Restore teak in Cabin
Mar 27, 2020
6
Catatilina 30 Brockport Yatch Club
Hi,
Our teak in our Cabin is looing slightly tired. What do you recommend to bring it back to life
dmax
Jul 29, 2018
1,347
Telstar 28 Buzzards Bay
Catalina used Watco's Teak Oil (can get at Home Depot) up until about 1990 for the interior finish, after that they switched to a lighter color, water based varnish. Here's a direct quote from Catalina:
The varnish is Target Coatings-Oxford, semi gloss. If your boat is oiled it is Watco teak oil.
~ Gerry Douglas
If you have an oil finish, you can lightly sand (careful with the veneer) to get a more uniform appearance and then apply some Teak Oil, which will darken it some. In good areas, just clean the teak with some citrus based cleaner and then oil. You can also expirement with lemon oil which will not darken the teak as much, maybe one coat of Teak Oil to get a uniform appearance and then go with lemon oil from there.
On my boat, I sanded the galley and nav station teak back to bare wood as they were pretty mottled and did 3 coats of Teak Oil, looks great. The rest is in good shape, the plan is to touch up a couple places with Teak Oil and then use lemon oil.
jimh2
Nov 17, 2018
5
Compac 27 Steele Creek Marina Kerr Lake
Teak Oil used religiously cleans it up and makes it look warm. Just finished the spring wiping down of the interior.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
Maroon Scotch Brite pads are great for washing stainless pots and pans too
Sep 25, 2019
38
CATALINA C27 Lk Norman NC
"They are not a good alternative to TP. ":biggrin:
In a scrape they will............once anyway :) ;-) ( bada bing)
gtg
Sep 12, 2019
103
Catalina, Hobbie 22, 16 Windycrest
~ Gerry Douglas
So leave the teak in place? I was going remove my companion way trim then varinsh it but the I started to wonder about leaving it in place and refinish it where it lies.
Id be disappointed to break it but im pretty sure I want to varnish the under side and put new sealant between the fiberglass and teak, correct?
dmax
Jul 29, 2018
1,347
Removing pieces and finishing at home is ideal but not necessary - many pieces are held in with screws under bungs, removing and replacing the bungs is not hard but you risk marring the wood. I finish in place unless it's easy for me to remove without damage. You don't need to finish the underside as teak is very rot resistant and with a good fit, not much if any moisture will get under there.
Sealing the underside of teak is usually unnecessary. The only reason to seal it is to prevent moisture from entering the wood and then lifting the varnish. This can happen on large pieces of teak (or any wood) that is flat and often wet. Toe rails and wood coamings are the biggest culprits followed by handrails. If they are removed, it is best to thoroughly dry the wood and seal with epoxy. All in all, probably more work than applying a couple of coats of varnish every few years. Use a good quality varnish like Epifanes and put multiple coats on, as many as 5 or 6.
