Reset Button on Diesel Engine
39
Catalina 310 Waretown, NJ
What is the purpose of the red reset button on the port side of the diesel engine? I found it the other day but I don't know what it does.
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
How about a more specific location?
Do you have an engine manual?
paulj
Aug 7, 2007
83
- - Oyster Bay, NY
You maybe looking at the reset circuit breaker for the DC harness. Its there to protect excessive current draw anywhere in the instrument panel wireing or engine wireing. Best to check the manual.
Dec 7, 2008
39
Thanks guys, It is the reset circuit breaker for the DC harness and the instrument panel. Also it is on the starboard side of the engine at the rear, right in front of the heat exchanger
May 3, 2008
190
Catalina 310 Catawba Island
Circuit Breaker in starter circuit
On my 2001 model #118 the reset button on the starboard rear of the engine is in the lift pump and starter circuit. If the breaker trips your engine will probably continue to run because the fuel tank is higher than the engine at most fill levels but you will not be able to restart the engine. If the breaker is tripped you will not hear the fuel pump when you turn on the key switch. I had some problems with the fuel pump 7 years ago or so and finally replaced it. I also had the preheat solenoid go out two years ago and had to bypass it until I could replace it. I carry a space breaker/reset but not the solenoid.
Dec 25, 2008
1,580
catalina 310 Elk River
Beware, only gravity feed untill ~3/4 of a tank, depending on the hight of the in-line fuel filter.
