Hello all,
I went to the yard to work on my 1990 30-2 yesterday and noticed that the sealant around the scoop transom is starting to come off. Well I actually noticed it early in the fall but it seems to be getting worse.
I'm assuming I should peel/scrape it out and replace it with something but I'm not sure what. Does anyone know if this joint is sealed only for appearance or does it serve some sort of waterproofing function?
Any suggestions on what sort of goo I should be using here?
Thanks!
Thanks!
