I have a CS 27
The engine is 8hp Yanmar ( YSE – Model 160)
I have had some serious transmission problems this season.
Here's what happened and the outcome.
I need to replace or rebuild my transmission.
I have a mechanic booked for the 11th September.
Should I rebuild or replace the transmission
Problems
Last season I noticed what looked like engine oil had come from the engine compartment and emulsified with sea water in the bilges. I kept cleaning it out- there was a lot of it....but it kept recurring. There was no leak visible. The engine oil is topped up and changed regularly. The dipstick was constant in the engine oil and always at pressure and to the cross hatched area.
After investigating at length I discovered what appeared to be an aspiration hose on the port side of the engine, just behind the starter motor. Lodged in the recess where the end of the hose protruded downwards was ..wait for it..a 1970's baked bean tin can.
This was full of thick black engine oil and had what looked like a very old wad of steel wool in the top....just under the surface of the oil. I removed it and emptied it-at the time I assumed it was an overflow of some sort. I replaced the can but it never rested in the same position and the oil leak into the bilges continued.
This season the same problem persisted. I changed the throttle and transmission shifter from a single handle to the two red/black handle shifter recently. I can/could get reverse gear in huge power. I was having difficulty getting any forward gear- huge revs and rpm but no power.
I finally remembered the transmission dipstick and oil port on the starboard rear of the engine. The cap to the plug/dipstick ( yellow) was firmly stuck. I was unable to move it. Eventually after much WD 40 application it gave and I was able to unscrew it.
Inside the plug it looked melted and the dipstick steel was missing. Obviously the oil came from the transmission ( I have learned it takes a half pint of engine oil- W10-30?).... and the transmission had obviously got so hot that it had melted the steel shaft of the dipstick out of the plug cap and it had dropped down inside the transmission. I took some advice from a mechanic. He thought I might be lucky and get away with my foolish errors.
Plan A: was to buy a flexible magnet and try and recover the steel shaft from the transmission sump/well. I tried this with two different magnets but no luck. I think I can detect the shaft but it may have gone horizontal and may be impossible to remove this way.
Plan B : Assuming the recovery of the shaft was to fill up with oil and see if the transmission will work. I know the risk is that the (cone?) clutch may have got so hot it could have glazed and then it's a $1000 rebuild and all the labour.
Plan C was to see if I can get the engine forward and dismantle the transmission, remove the shaft and then resort to Plan B. The mechanic who gave me advice suggested we briefly try the engine- it started and turned over - I can still get reverse.
I regret not thinking of the transmission/oily bilge link before. In my defence the previous owner indicated transmission oil should never/hardly ever need changing- ok it's not much of a defence but it's all I have!
It seems certain now the clutches are ‘glazed’ and slipping in forward gear.
1. Does anyone know of a place where I can order a new/refurbished transmission for the above engine please?
Holland Marine Products in Canada ( East Coast) are closed for three weeks in the summer and I cannot find a supplier or seller?
2. Does anyone have a YSE8 Yanmar they are breaking for spares or that they wish to sell ( in reasonable condition?).
I have spoken to a couple of dealers in the Bellingham area and they both think the transmission needs re-building ?
I prefer to purchase in the USA as the local dealers are usually double the price for the same item.
I have found a YSE8 in Ontario but it’s $2000 and then the shipping( another $1000) plus fitting ( a further $1800)
3. Is there a transmission repair kit available for the YSE 8?
Thank you,
Sorry for the long post,
Chris Holmes
(Captain Caliamari)
[SV Squid Vancouver.BC]
__._,_.___
Problems
Thank you,
Chris Holmes
(Captain Caliamari)
__._,_.___
