Lots of issues; get some good references
Duane, I've also been researching repowering. Some thoughts...First, lots of variables when picking the new engine & installing it:1. New engines of similar hp rating tend to run at higher rpms than older engines (due to emission standards changing); this will effect your shaft rpm & may require you to repitch/resize your prop.2. You can consider rebuilding your transmission vs. buying a new one, so you order the engine 'bobtail'; this can save you some money with the same likely longevity (depending on transmission's history and type. May be a bad idea in your case if you're increasing power substantially.3. Footprint & geometry of new engines generally differ from older engines as boat builders have reduced the engine box in order to increase interior room; modifying engine beds is possible but a hassle, time consuming and an expense, so picking an engine most agreeable to existing bed, shaft length, height, etc. can make the project go much faster/cheaper. (You've no doubt already looked at engine measurements; don't overlook other engines if you don't already have a good fit).This is of course the time to shop engines - boat show season. Look for promotionals that not only reduce price but may also offer free freight to your dealer and/or even spares kits when a purchase is done at a show. Westerbeke offers all 3 right now.Dan Spurr's book (sorry, title escapes me) illustrates a complete engine replacement and was helpful, I thought. Nigel Calder's early chapter on powering a sailboat in The Cruising Handbook is excellent and a good way for you to check hp/rpm assumptions, and it uses the same approach as Dave Gerr's 2 books (The Propellor Handbook and The Nature of Boats) which are excellent...but Nigel covers the same ground quite clearly. Gerr offers a clear way in which to determine your prop pitch & size, BTW.One final observation: we've repowered twice & I think it's fair to say that while it's easy to find vendors who will sell you pieces and labor, no one vendor is incented to care about your total repowering project (beds oka?; will you need to reroute exhuast, fuel and raw water lines? change transmission ratio at the time you install a higher rpm engine? shaft okay?prop? compatible with alarms, current instrument panel? it's a lengthy list...). I'm finding that locating a local independent mechanic to 'oversee' the project is a big help while not adding a large expense; in fact, he may be saving me money. The labor rate may be less for an independent due to no overhead cost of a shop. Someone who's repowered a number of C30's will know exactly what is required and what the surprises might be, yet can leave you to do all the unbolting/bolting, running around town for new fuel/exhuast/water hoses, etc.I'm finding that staging the work is a key task, since the engine must be pulled so the transmission can be removed and rebuilt, yet I don't want to lift it out until the new one is available. It's time to pull & replace the 23 yr old fuel tank, which is behind the engine. So the actual critical path is to line up 'time to make new tank' with clean/repaint bilge/engine bed area, run new ground wires, etc. on my end with the shop's time to rebuild the transmission. Staging the delivery of the new engine/yanking the old one is almost incidental re: timing, tho' how to get a 600# engine out is a challenge, given no propulsion.Good luck!Jack
