Reply
L
Lee Y
The bunks are bolted to the trailer frame with two 1/2" diameter bolts. I'm not planning to leave them on the trailer. The channel is about 1/4" thick.
L
Lee Y
Wrong reply
I responded to the wrong post. These type of things are happening a lot. I think I'm losing my mind. Sorry
Oct 3, 2006
1,029
Hunter 29.5 Toms River
Register?
why don't you register,and then you will be able to delete posts (and have a profile!)
Lee Y
Jun 5, 2004
43
- - Muskegon, Michigan
How do I delete a post
I'm registered but can't figure out how to delete a post.
Dec 2, 1997
9,011
- - LIttle Rock
To delete or edit a post (it can only be your own)...
Click on "edit/delete" at the bottom of your post. If you don't see "edit/delete" either you aren't registered or you aren't signed in. If you are registered, click on "forum settings" at the top of this message board page to log in.
Oct 3, 2006
1,029
You won't
you won't be able to delet posts that were made while not registered, only Phil (and maybe some others?) can do that.
