The bunks are bolted to the trailer frame with two 1/2" diameter bolts. I'm not planning to leave them on the trailer. The channel is about 1/4" thick.
To delete or edit a post (it can only be your own)...
Click on "edit/delete" at the bottom of your post. If you don't see "edit/delete" either you aren't registered or you aren't signed in. If you are registered, click on "forum settings" at the top of this message board page to log in.
