I've been having a problem with the "Reply w/ quote" feature when using Safari on my iPhone. I can select text and tap Reply w/ quote once and it works properly. The problem is that if I want to insert a second quote in my reply, when I try to select the second block of text I can't select anything. The iOS cut/copy block appears at the top of the screen as if I had selected something off the top of the page, but I can't get it to select what I'm looking at. Not sure if this is something about the JavaScript on the page or a safari bug, but figured I'd mention it.
