I asked before but I can't find the answer given: What kind of wood is used in the interior and are there stronger options. Thanks in advance.
If you're going to drop the mast aft, you'll need to remove the front pin and let the tabernacle pivot on the rear pin. What you need to do first is to set up something at your stern pulpit temporarily just to have something for the mast to lay on so that it doesn't hit your companionway sliding hatch. I've used a small step ladder and tied it to the stern rail. Once you get that mast down you want it to sit on something high enough to clear the cabin until you can remove the rear pin.Thanks guys. This week I will replace the wood and all the standing rigging. The mast has two pins, one bigger than the other. Should I remove the smalller first and bring the mast down on the cockpit or vice versa? Clearly not a one-man job but I figure I can ease it down with the halyards.
