ok, have you tried the gentle persuasion motor tap with a rubber mallet? The "moan" sounds like the motor is just stuck. DC motors have this problem of being slightly offset.
To answer your last question...
Your pump (old or new) has a high and low pressure cut off switches, built in the pump head. Capacity or flow rate should not be a problem for sporting boat sizes.
Jim...
