Water leaking from the water heater located under the settee, against the galley counter on the starboard side, has saturated a section of the teak and holly sole and rusted the salon table base. Attached photo shows the location of the stained of sole and rust on table base.
I'm looking for guidance on the steps to remove the sole plate that the table base is bolted to and passes under the settees and galley counter.
Also suggestions on which manufacturer would be the best replacement for what I believe is a discontinued Force 10, 6 gallon water heater. I've found 4 different manufacturer models. Seaward, Camco, Kuuma and Atwood.
Thank you for your posts.
Mark
Mark
