Hello Again,
On Tuesday, following 4 hours of really good sailing, the transmission gave out. Started up the motor...everything sounded fine...but then engaged the transmission and got bad grinding/clicking/rubbing sounds.
Sailed the boat back into my marina, up the fairway, and turned into my slip...all under sail...pretty darn proud of myself.
Anyways, yesterday I had a more mechanically knowledgeable friend come over and we checked things out. Engine is fine. But we could engage the transmission and then hold the prop shaft. Can hear the transmission turning but the prop we can hold still. Just grinding/rubbing.
The transmission cable leading to the swing arm on the side of the transmission seems fine.
Our plan is to remove the old transmission tomorrow and install a new one. Old one is Hurth HBW 50. Can't find them on-line anywhere. Appears they are replaced by ZF-6M.
Anyone ever replaced their transmission? Any thoughts or words of wisdom? What about installing ZF-6M?
Engine is Universal/Westerbeke M-25.
Appreciate any thoughts.
Thanks again. This is a great forum.
Cheers,
Jim
Cheers,
Jim
