Replacing the throttle
Jul 27, 2015
2
Hunter 376 Mt. Pleasant, SC
My Hunter 376 has the original throttle, throttle cable and shifter. This wkend we repaced the two cables and hooked the new ones up to the new throttle, but it seems stuck in reverse. The directions sent with this new replacement throttle through Hunter are not specific at all.
Reaching out for anyone who has done this that may give us some help.
Thanks.
Feb 6, 2017
13
Hunter 376 St James City, FL
I am looking for your experience. Did you figure out how to install those cables? I am preparing to route new cables this weekend. I will also be replacing the shifter with a new after market brand sold by Sailboat Owners.com Thanks.
Sep 26, 2008
765
Hunter 340 0 Wickford, RI
I did mine (2000 - 340) a few years back. I have some photos on this site of the job from engine and transmission, and at the throttle itself. Also the routing process.
From what I'm reading, the transmission being "stuck" in reverse....it may have been in reverse when it was attached on both throttle and transmission ends.
If the throttle itself is in reverse and the transmission also it may not go forward.
So my advice to you is double check the positions of the throttle on the engine and transmission before disconnecting either end. Label the new cables to not get them confused at the throttle.
But above all, be certain of "neutral" at all 3 ends (transmission, engine and throttle)
Aside from that, it's a fairly easy job, routing the cables being the hardest part.
Take your time, check and recheck as you go no points of the new cables kink. Make wide easy loops in the cable, but cinch them up tight to the existing bundle. To loose and they will cause throttle creep.
Hope this helped.
