Has anyone got a good solution to replacing the particle board table top in a 22' once moisture destroys it? I don't have the "New Yankee Workshop" at home to glue up and plane a top. I'd like to find a way to purchase a material that's already the correct thickness and can be cut to shape. Laminating something with formica is no problem. Don't know if there are plywoods that will stand up to constant moisture. Solid hardwood is likely to warp if not built up as an alternating-grain laminate. Worried that the synthetics are heavy, but have never handled a piece. What makes a good (or great) solution?
