Peggie's Right of Course
Her explanation of the dip tube is right on. The discharge fitting is at the top, and the fitting has a tube, cut slanted at the bottom, that reaches to the bottom of the tank to allow pump out. Now, TECHNICALLY, the tank when pumped out leaves something at the bottom, but with a couple of rinses should leave very little offensive material. And even if it leaves something, it's at the bottom of the tank and not in the hose. That was one of many pieces of "Peggy wisdom" that I took advantage of. Another was replacing the small vent line to the starboard capped vent thru hull with a 1" vent line to a standard through hull. I had to drill out the old hole and put a new backer in. It sits far enough above the waterline, even when heeled, that there is no seacock. As far as the 5" above the tank for all fittings, I think I was able to squeeze it in with less, but not much less, and SQUEEZE is a key word. A key to fittings and hoses that I learned the hard way - I got the hose (AVS96) at http://www.aussieglobe.com which I understand is the old Sealand hose and very good. You need their PVC fittings to be able to attach the hose, and I found that using a hair dryer and a little lubricant was necessary to get the hose on the fitting. The mistake I made was putting the fittings on the elbows into the tank and THEN trying to get the hose on. Put the PVC Sealand fittings on the end of the hose where you've got room to work, and THEN lead them to the tank and glue them up to your PVC elbows. Hopefully that makes sense. As far as running the hoses, tank to head wasn't too bad, with decent access under the rear cabin berth. The boat had a macerator plumbed in previously, but I had no use for it on the Great Lakes, so I left it out of the equation. The pumpout and vent hoses were a little bit of a challenge, and probably would have been easier with a little assistance, but I was solo the weekend of the install.As far as fastening the tank in, there is a molded in platform that the tank sits on. It had four holes, approximately 1" in diameter drilled in it, forming a square. The old tank had two steel straps that went in one hole, out the next, and then around the tank. I used the same holes, and same principle, but rather than stainless straps (as I don't have the equipment to secure them) I used two ratching tie-downs. One thing that I did have to fashion was a support for the back of the tank that matched the angle in the tank to support it, while clearing the fuel hoses. Was really fairly simple, and not one of my prettier attempts at carpentry, but no one would ever see it. Some marine ply with a few coats of epoxy to seal.As I said, I'll try to get some pictures for you this weekend, or shoot me an email and I'd be happy to respond with further contact info if you want more help.T J
