Good idea... but....
I like the idea of cutting an access panel through this wall, so I ran it by a friend of mine who's a boatright. He thought it'd be fine, but offered one caution.Having once conferred with a friend who worked at Hunter, the friend had told him that everything in a Hunter was put there for a very specific reason. If something didn't add to the structural integrity or serve the decorative marketing needs, it didn't go on a hunter. Hence, if there's a 3/4" piece of plywood there, you can bet your bottom dollar there's a structural reason for it. One should be cautious when cutting a hole large enough to compromise the structural integrity this board was designed to provide.My friend suggested that after cutting the access panel, I use some pieces of hardwood to make a lip around the edges that'll hold the panel in place when it's returned to the board. A generous number of screws should be used to hold these wooden lips in place, and several screws used to secure the panel to these lips.The combination of screws securing the lips to the wall, and panel to the lips, should help restore some of the stability lost when cutting out the panel.This sounds to me like good advice.
