I'm planning to re-pack the stuffing box on our 2007 H41AC some time next year when I can get it hauled out. While I'm at it, I should probably replace the hose, too. The hose is about 5-1/2" long and I measured the O.D. as 3" and O.D. of the snout at the aft end as 2.725". The hose O.D. seems reasonable but the snout diameter seems odd. I measured using vernier calipers that I keep on board.
Has anyone replaced the hose on theirs and, if so, what size and type of hose did you use (metric or Imperial)?
Also, there appears to be some discoloration (possibly even some build up) on the shaft right where it enters the gland. When repacking a stuffing box, has anyone found a wear groove or scoring on the shaft and, if so, how did you go about addressing it? I suppose that the hose could be shortened by a small amount to get the packing to ride on a different part of the shaft.
