Hi folks, replacing a stanchion base on my 331. The description said "stanchion base - wood rail", and it noted in the schematic that it was replacing an obsolete part. I don't have a wood rail, but I was at the right place so I ordered it. When it arrived, it is not exactly the same. The one that goes with an aluminum rail is different, it is raised at the inboard side to let the water run underneath. (See the attached service bulletin for the difference between the two; scroll down for the second one).
Has anyone replaced one with the other? They do not make the other anymore. I wonder if it will be wobbly?
Thanks!
Thanks!
