Replacing spreader end. Locktite?
Mike25
Feb 14, 2022
20
Macgregor Venture 25 Atlanta
Venture 25 1975
Recently broke a spreader end cap and ordered new ones that are metal. They are two pieces. The end pinches the stay as it's tightened into the cap that fits into 7/8 tube with two 6 by 32 machine bolts. Should I use some type of thread sealer or locktite on these threads? Seems like they could loosen with vibration. I do want to be able to remove them if needed. Any recommendations appreciated
May 16, 2011
555
Macgregor V-25 Charlton, MA- Trailer
Venture 25 1975
Use Locktite blue. It will allow disassembly.
Tedd
Jul 25, 2013
793
TES 246 Versus Bowser, BC
Following on to @Tsatzsue 's comment, there are two good choices for your application. Loctite 243 (commonly known as blue Loctite) is fine. But, strictly speaking, the ideal product for 6-32 screws is Loctite 222 (purple), which is very similar to 243 but intended for smaller thread diameters (below 1/4 inch).
Given the price of Loctite you might want to have just one kind, in which case 243 is the better choice, since it's okay to use on smaller screws. But make sure you have good-quality screws whose sockets won't torque out (or heads torque off) when you go to remove them, later. Hex socket machine screws would probably be best.
capta
Jun 4, 2009
5,006
What does the manufacturer of the new parts recommend?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I learned something today, thank you!
crpdm
Oct 23, 2008
38
Macgregor 26D Highlake IL
Is the whole thing metal, or just the cap? Loctite will cause plastic to become brittle and crack.
Likes: Tedd
Tedd
Jul 25, 2013
793
That's a really good point, @crpdm . And the Loctite doesn't even need to actually touch the plastic to degrade it. Although, outdoors I suspect even a small air gap is safe.
