Replacing side upper stay?
Aug 18, 2014
5
Oday 222 Sebago Lake
I am about to replace the port side upper side stay and am not sure if the upper connection is a screw/bolt or pop rivet. Before I drop the mast I need to know if I need to bring along a pop rivet gun.
Apex
Jun 19, 2013
1,229
C&C 30 Elk Rapids
question becomes the type of fitting swaged onto the wire rope. I have a clevis pin with cotter pin retainer up top.
Oct 19, 2009
97
oday 22 Lake New Melones
My upper shroud is attached to the mast tang by a jaw fitting with a clevis pin and a cotter pin.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
My Dwyer mast on my 192 has a tang riveted to the side of the mast, and a fork type swage on the shroud, which attaches to the tang with a clevis pin and ring-ding. Look for Loos Fork Ends (Swage) on this page: http://www.apsltd.com/c-908-thimbles-sleeves-and-swage-fittings.aspx to see what my shroud fittings look like.
I can't imagine any reason for it to be different on a Z-Spars mast (which is the other mfg that did masts for 222/192.) There is no reason to permanently affix standing rigging to the mast, as in, rivet the standing rigging to the mast. Standing rigging should always be removable/replaceable.
Aug 18, 2014
5
Thanks for the replies. Now that I think about it it does attach with a clevis pin. You get brain cramps when you age. Thanks again. Should be an easy fix.
