Masthead sheaves
Hi Tom,As you've figured out by now, I'm a little wordy. It comes from the Engineer in me, I guess. Since you once asked, I'm a mechanical engineer in the automotive electronics field, mostly doing Project Management. Serendipity has lead me to the Atlanta area, wonderful weather, beautiful surroundings, but a lack of big water to sail in. The masthead has two main halyard sheaves, but only one is used. I think it'd be a waste of money to change them both out.For the questions concerning the spinnaker, it would be nice to hear from someone out there that has a factory installed spinnaker package. I had Hunter send me two pages eons ago showing the factory spinnaker setup. Most of it is definitely add on. However, you should (I think) have blocks and exits already in the mast.The standard package should have an exit block for the spinnaker halyard 18" above the forestay. It should have an exit block for the topping lift 6" under the forestay. When I added my spinnaker, I checked with Isomat about using an oversized spinnaker, and while they would not endorse it, they agreed that the mast was overbuilt and would hold it. With that in mind, I added a bail at 38' above the deck (about 5' above the forstay attachment) and put an external halyard thru a block at that point. I use the spinnaker halyard as the topping lift. The drawings show the standard chute halyard & topping lifts as 3/8", but I've found 7/16 to be easier on the hands.While its down, I would try to run the chute and topping lift halyards. You might try something like an electricians snake, but it would have to be pretty long. Standard line lengths for both chute and topping lift are shown as 90', but that seems long, especially if you end them at the mast as Hunter shows and don't bring them back to the cockpit. I would probably recommend doing that, but lets hear what others have done.If you want, I have Hunter drawings of their setup and could fax them to you. Let me know.
