N
Nick Jeszenszky
I am trying to reinstall the main halyard sheave and shaft pin at the base of the mast. The pin came out along with the sheave and it looks like it should be held by a cotter pin inside the mast. That would mean that the mast would need to be unstepped to install the cotter pin through the shaft pin inside the mast. Is there another way of doing this without unstepping the mast? The shaft pin arrangement is the same on the opposite side for the jib halyard and spinnaker. If I wanted to change the sheaves how would I remove the pin?
