Don
Has anyone replaced the thermostat or the high temp guage on a Seward 6 gal water heater? If so, where/how'd you get the parts? Read on..I think the Seaward water heater on my '93 H37.5 is overheating. The water is pretty much boiling when it comes out of the tap. Plus, this weekend the 30amp power inlet on the boat melted and nearly caught fire from an apparent overload (I was only running the cabing heater and H20 heater, which I have done many times before.)From the parts diagram I see there is the typical thermostat plus a high temperature guage or something like that (which is different from the high pressure relief valve.) I do not have the manuals with me so I can't order the parts until later this week. Thought I would check here first.Thanks in advance for any advice.
