With research, recommendations, and Peggy's book, I'm currently planning and acquiring components for the replacement of the sanitation hoses in a 2005 Beneteau 323 with the original Vetus holding tank.  I'm going with the Raritan Saniflex.  Since the original tank fittings seem to be loose and caked with old sealant, I'm going to replace them as well.  I've purchased replacements from Beneteau parts department (see attached).  My question is this.. given the tank is likely polyethylene and the fittings, nuts, and flanges are nylon, should I be applying any kind of sealant beyond the compression fit to keep odors in the tank?  An o-ring or gasket of some sort?  Or nothing needed?  If sealant, what kind of sealant would be recommended?  And where? On the inside between the top of the tank and the inside flange like it currently appears to be?   I'd appreciate any guidance here...
