I recently purchased a new set of rope clutches to replace the worn clutches on the port side of my 1997 HR31. I was able to access the aft nuts by simply removing a ceiling panel in the aft cabin. The forward nuts & bolts are positioned slightly ahead of the aft cabin bulkhead above the galley ceiling. This ceiling seems to be completely inaccessible. All the material appears to be permanently installed. I can't see any means of accesing the forward hardware without doing damage to a part of the ceiling. Any advice would be appreciated. Meanwhile I have installed larger diameter lines)
