Replacing roller furling
John
I hope to replace my old CDI reefer, continuous line, roller furling over the winter. I want to do it myself. The mast will be off the boat ( 83 Catalina 30 TR) Since I want to do it myself what brand would be the simplist for me to attempt?
May 18, 2004
385
Catalina 320 perry lake
CDI
My son and I installed a CDI Flexable Furler on our last boat (Gloucester 22) and it was pretty easy. The furler worked great.
May 31, 2004
858
Catalina 28 Branford
Another vote for CDI
I think CDI is supposed to be the easiest dyi installation as it does not require recutting the forestay (usually), and has no upper swivel unit. I have the CDI on my Oday 23 and love it.
Jun 4, 2004
14
Catalina Capri 22 357 Sarasota on trailer at SSS
CDI installation
Bill (or anyone) can the install be done with the mast up? I need to replace (or adjust) the internal halyard and may need to remove the extrusion to get to the top where the halyard enters. mike
Thomas Wanderer
harken
I installed a harken system on my hunter 25 it was easy and it has worked flawlessly since (2 years). I replaced the forestay and had it sized by west marine for my boat and my furler.
May 22, 2004
130
Other CS27 Toronto
The Hood Seafurl 707 SL
may be a better deal for your size boat John. I found it to be comparably priced, in my neck of the woods, to the CDI FF6 and I think the Hood is a better unit. It can fit over an existing jib stay making for an easy install. Kevin
Joe
Jun 1, 2004
8,259
Profurl is the best....
...that's my opinion.
John
Thank you all.
I appreciate all the responses. I hope to pick one and tackle the job before it gets too cold.
Mar 21, 2004
343
Hunter 25.5 Carlyle, IL
CDI for a Catalina 30 tall?
CDI might be the simplest to do, but is it good enough for the conditions you sail? Would something more robust be necessary to reef in a heavy blow?
May 18, 2004
385
Mast up installation
The directions say you can do it with the mast up but I didn't. I was very anal about checking and rechecking my measurements/fit before I cut the plastic foil. You do use your existing forestay and turnbuckles without alteration. Others may be more robust but so is their price.
