I am having issues with the GPS heading indication on my Raymarine E120. As indicated by the RED vector line, it sometime is correct and is sometimes out by up to 120 degrees. Sometimes it responds correctly after I turn the boat in a circle, sometimes not. Green vector line works correctly along with "auto" setting on autopilot, as I changed fluxgate compass over the winter. I suspect problem is the RS 130 antenna. I took a look at how it's attached from inside my port cockpit locker. I could not find any screws, nuts or thumbscrews, only a thin wire connected. Is it glued down at the factory with 5200? Anyone have any advise as to my issue with the heading problem?
