replacing portlights
Jul 28, 2013
56
Hunter 34 Lake Norman
Does anyone know the thickness of the fixed portlights on a hunter passage 42
PNWE36
Nov 1, 2022
37
Hunter 36e Thunderbird W. Vancouver, BC
Hi,
I replaced all the portlights in my 2011 H36e this spring. I tried to find the same information you are looking for. No luck. I removed them. The side ports were 9/16" thick. The forward "windshield" was 3/8" as it needs to bend more. At the local plastics fabricator 1/2" was the max that they carried, anything thicker was custom so I went with that. I read on-line from several sources 3/8" thick is all you need. I removed the old windows so the shop could use them to make templates. Said they couldn't use the windows as templates because of the bevel.
I installed the new windows using high strength 1/8" thick glazing tape. I wanted the 1/8" thickness to provide a gap for the sealant. I used Dow 795. The old windows were held down with screws. Many posts said to hold them down with screws until the sealant cures and then remove and fill with sealant. I chose not to use screws and weighed the windows down using dumbbell weights.
The most difficult part of the project was getting the fiberglass frames level for the 1/8" tape to bond evenly.
  • Helpful
56
Thank you for the information I would never have thought they were that thick.
