Hi Folks,
I'm curious if anyone would strongly advise against leaving the mast up while replacing a partial bulkhead and rebedding the chainplate on the port side (while the boat is in a slip).
The chainplate ripped through a rotted portion of the bulkhead this weekend on my first sail on this boat. I am anxious to get it up and running again. Did some reading on this site and thankfully found another owner who in quick fix mode, partially replaced the bulkhead by cutting out the rotten piece and replacing with new, then sistering more ply to add support. Then rebedding the chainplate using longer screws.
I realize this may be a shorter term fix.
What I'm curious to know is, the boat is in the water at a slip, the mast is still up and tied using 2 halyards on the portside to two stanchions- and the stays are still attached to the loosely held chainplate that is no longer embedded in the bulkhead. When I remove the stays from the chainplate to inspect, rebed etc., can I also somehow hook those stays to the stanchions? or would the pressure be too great and possibly cause the stanchions to pull out and the mast to fall over? also concerned about wind...
thanks,
Pat Tobin
I
thanks,
Pat Tobin
I
