Replacing Original yellow bilge hose on O'day 28 1985
Nov 29, 2021
28
O'Day 28 Milwaukee
Hello, I am a new 1985 O'day 28 boat owner and new to sailing as well. Someone decided to abandon her and I would like to bring her back to life as best I can. The survey I had done checked out very well for a boat of her age but like anything there is still a number of projects that will need to be done. I do like to work on things and looking forward to this project over the next number of years. I have a crack near the bilge pump on what appears to be the original yellow ridged hose running to the stern of the boat. It was recommended that the hose be replaced because if it cracked there on its own then other cracks could be just around the corner.
Question, has anyone had to replace this hose and if so what am I getting myself into? This will be one of my first projects and unless its a nightmare I would like to tackle it myself. Does not look like much room getting back to the stern for where this hose connects only poked my head back there did not get too much into it yet and also not sure about how the routing of the hose might be? That does not look too bad though. Thanks in advance.
dmax
Jul 29, 2018
985
O'Day 35 Buzzards Bay
My boat is similar to yours - I replaced the bilge pump hoses recently (manual and electric). It wasn't too bad until I got to the stern like you say, I crawled back as far as I could get and was able to just barely reach the through hull for the electirc pump hose. It was tight in there - bring a cushion to pad your body. The whole job took about 4 hours including replacing the stern through-hull. This is definitely a project you should do yourself - you'll get to see how your boat was put together.
Nov 29, 2021
28
O'Day 28 Milwaukee
Can you tell me what type of hose you used and do all of these boats have a manual bilge as well? I have no info from the previous owners so not 100% sure what is standard equipment, required and/or added. Appreciate the quick reply
dmax
Jul 29, 2018
985
I don't know about the 28's but I should think you have a manual bilge pump standard as well, it should be in the cockpit with a handle around somewhere to operate it. You can also look in the bilge to see if there are two hoses. Mine has a white cover - here's the best picture I have of it (it's in the yellow rectangle):
This is the hose I used (good stuff) - 28 feet of the 1 1/8" for the electric pump, 31 feet of the 1 1/2" for the manual pump with about 3 feet of each left-over:
Nov 29, 2021
28
O'Day 28 Milwaukee
Thank you very much, my first of many projects, I did find out the light at the top of the mast is burned out as well. Not ready to run and fix that yet though. This is my bilge area, not sure what the smaller diameter hose is for? the yellow hose is cracked just outside the picture
4,794
Oday 322 East Chicago, IN
Ha…I was trying to figure out when O’Day used yellow bilge hose….now I see. That started out as white hose oh so many years ago!
Greg
dmax
Jul 29, 2018
985
The larger hose (yellow) is the manual pump hose, the white cylinder that says Rule is the electric bilge pump with a non-standard hose (it should be reinforced so it doesn't collapse, though it will be under positive pressure). Good that you plan on replacing them :thumbup:. The bilge is in good shape for an "abandoned" boat.
Nov 29, 2021
28
O'Day 28 Milwaukee
I think I will find a lot of things that used to be white on this boat... :) You are not too far away, this boat will have a slip in Milwaukee once I get her there next year.
Nov 29, 2021
28
O'Day 28 Milwaukee
I wish I knew more about her but the surveyor said whoever did have her took pretty good care of her and that things you might expect of a boat that age he saw but nothing major or as he said the things he found would stop him from going out on her. I really appreciate the quick feedback and I will plan on replacing both hoses. Not looking forward to squeezing back in the stern area though. I know I will have more questions, maybe someday I will be the one helping out the "new guy".
Jan 7, 2011
4,794
i bought my first boat (Hunter 280) in Milwaukee.
sailed her to my home port in East Chicago, In in 2 days! Lots of fun.
The work never really stops!
I try to do work over the winter, so I can sail. During the summer…
My “To Do” this year is a bit ambitious….
1) Replace traditional stuffing box with Volvo dripless…just put it on today, but still need to reconnect coupling and tranny.
2) Make new radio console for VHF, stereo, Sirius receiver and new battery monitor…installed.
3) Replace under the sink drain hose in galley (rotted), rebed thru hull…done.
4) Repair Mack Pack sail cover…. In progress….had to make a palm to sew the sail cover ;-)
5) Upgrade primary winches, and move old primaries to cabin top…. Started, it not too far along.
6) Relocate engine control panel… add fuel gauge and hours meter. Not started.
7) Refill binnacle compass….done
Enjoy the journey… and get out and sail when you can.
Greg
Jan 4, 2006
6,510
Only four hours :D , that's such a small job, hardly worth mentioning, but you will get to see how the boat is constructed. Be sure to use the original hose as a fish line for pulling the new hoses.
Someone decided to sell her, but I doubt that boat ever suffered being abandoned. The bilge appears to be in pristine condition and that's usually the grubbiest part of the whole boat. I'd say you've got a real keeper. Treat her well and she'll take good care of you.
Nov 29, 2021
28
O'Day 28 Milwaukee
That's quite a list!, I have do things in between my day job. I have to ask when you spent the night going to your home port where did you sleep along the way? My wife and I would love at some point to sail to Beverly Shores to visit friends once I am a more comfortable sailor. Maybe if you ever feel like taking the "new guy" out and giving me some pointers I can come down. We can stay with our friends in Chicago or Beverly. We lived in Chicago for about 15 years when we were younger. If you want to keep in touch directly my email is parks1127@gmail.com
Jan 7, 2011
4,794
I took delivery of my boat in the spring…my 2 boys wanted to help bring it down. One was in college, but had a long weekend over Good Friday. I had never seen the boat with the mast and sails on…and had sailed about 5 times prior to taking delivery…I was greener than grass.
My wife drove us to Milwaukee in the rain and sleet…38 degrees and nasty. Worse yet, winds were blowing from the East, around 25 knots…but I didnt really know what would mean on the Lake.
The broker kept asking me if we really intended to out that day (my first clue)…and I said “yes, we have been planning this for a while”. Then he asked where we were going to spend the night, and would I please text him when I pulled in somewhere for the night (my second clue).
We left the marina, thinking why everyone was so worried…we didn’t even have our life jackets on.
As soon as we got outside the break-wall, we knew!
As we bashed through the 8-foot waves, under engine power, we were all seasick in a matter of 30 minutes. We were wet and cold and sick. It was a most miserable first day of boat ownership ever!
Luckily, the little Yanmar kept humming, and we made it as far as Winthrop Harbor. We pulled off the Lake, ate (funny how the seasickness was gone as soon as we stepped on dry land), slept on the boat that night watching lightening and hoping it didn’t hit our mast.
The next morning, we woke to sunshine, and wind off the west (so almost no waves), but it was still blowing hard. We put out some jib, and ran the engine all the way home.
I made a lot of mistakes on that trip, and am fortunate nothing bad happened. It takes experience, growing your skills, testing yourself a little at a time, and not doing anything that makes you too uncomfortable.
That was 11 years ago or so…and I have gained a lot of experience. Today I am comfortable sailing alone most of the time (no, I didn’t ruin the boys for sailing…they are grown and moved away)…in almost any weather. My wife goes out on perfect days (sunny, warm, not too much wind, and flat seas). Otherwise, I am usually solo.
I do like to sail and spend the night by Beverly Shores and the Indiana Dunes Lakeshore. There is no anchorage there per se…you really need to pick your weather window carefully. Big waves would be a tough anchor out there. I look for a south wind, then not big seas close to the south shore.
This is from a few years ago…
Michigan City is close and has a nice marina.
Always happy to take folks sailing…I will email you my contact info.
Have fun with the new boat!
Greg
dmax
Jul 29, 2018
985
Forgot to mention: while you're back there, you should also replace the cockpit drain hoses, they use the same size hose as the manual bilge pump on my boat. They will likely be in the same shape as the your bilge hoses.
Jan 7, 2011
4,794
Good point.
Last years winter layup project included replace 8 above-the-waterline thru hulls. 5 of them were in the back transom area (2 scupper drains, 2 propane locker drains and the bilge pump one drain). I was able to remove a “fake wall” at the foot of the berth and gain access to the area, but it was a stretch to get to all of the fittings. The scupper hoses didn’t look too bad, but the LPG locker drain hoses are being replaced this winter.
While I was in there, I rebed the swim ladder bolts as I saw a little leak when it was raining.
Greg
Nov 29, 2021
28
O'Day 28 Milwaukee
Thank you all very much, very much appreciated. Sounds like I have my work cut out for me.
Sep 24, 2018
2,613
O'Day 25 Chicago
I highly suggest you remove the screws in the bottom of your bilge so they can be resealed. If water gets into the keel it can expand crack the keel over the winter. This happened on my 25. It was not a fun project
