Tom
I am considering changing the original harken furler to a Facnor STG 3T wire furler, so I can use a larger headsail in light winds, but the main reason is so I can remove the jib when the boat is not in use. I am wandering if anyone else is using a facnor wire furler and if so would you recommend the change.Tom
