Replacing Oil Pressure Switch
Clydo
May 28, 2013
371
Catalina C310 SF Bay/Delta
When replacing this switch on the M25XPB do you need a "plug" to keep oil
from "pouring" out during replacement or just let it "trickle" out until replacement in
place? Am about to start tracking down why buzzer not working and this
is one possibility _among lot of others -have to think about that. Could possibly be loose wire
(hopefully). Thanks for any answers.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Nov 16, 2012
1,055
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
If you take the wire off the switch does it buzz? If you ground the wire does it buzz? Divide the system in half and see which half has a problem.
Harlan
Jun 4, 2004
99
Oday 34 Niantic
If the XPB is the same set up as the M25 (I think it is) then the oil pressure manifold block is well above the oil pan. No oil will leak out at all - so long as you don't start the engine!
May 20, 2016
3,015
When/if you reinstall it don’t use Teflon tape or other material that might prevent the switch from getting a good engine ground.
Les
Likes: Alansails
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Loose terminals are a common problem with this switch, Clyde, so it would be a good idea to secure the terminals and wires with additional zip ties when changing out the switch.
Clydo
May 28, 2013
371
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Clydo
May 28, 2013
371
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Mystery solved. Turns out was 10 amp "circuit breaker" attached to preheat solenoid which is in the buzzer
circuit. Thanks for all you helpful suggestions. Great list.
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
Likes: Tom J
KZW
May 17, 2014
831
Catalina 310 #307 Bluewater Bay, FL
Can you post a photo?
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
KZW
May 17, 2014
831
Thanks for the picture!!!
Where did you get the K&N air filter?
Part Number?
May 20, 2016
3,015
Part Number?
Look at the Catalina 34 (c34.org) site. Has all that info and more. There was also a recient discussion on the Catalina 36 site about them
Mar 22, 2009
360
Catalina 310 Gulfport Small Craft Harbor, MS
Hi Folks,
Jumping into this thread late. The issue for me is my oil pressure warning light and horn started going off today. No leaks that I can see. Oil was a little low on the dipstick but I added some more and now it is a little over full. But still getting the horn. I will check that 10-amp CB mentioned. But anything else I can check?
Thanks,
Jim
#178 "Polaris"
Nov 16, 2012
1,055
Hi Folks,
Thanks,
Jim
#178 "Polaris"
Jim, here's a corrected schematic of the engine and pod circuits (the one in the 310 manual has some errors). A quick description of the oil pressure circuit is: "The lift pump is connected to the "P" terminal on the alarm buzzer, which is also the side of the oil pressure switch that is not connected to 12V (coming from the Pod). On the schematic it says Oil Pressure Switch. That is all part of the (complex) circuitry that runs the lift pump when the glow plugs are energized or when the oil pressure switch is closed, and sounds the alarm the rest of the time."
So if the glow plugs are energized, 12V gets to the lift pump through the 10A breaker. If the glow plugs are not energized, and the oil pressure is low, the oil switch is open, the lift pump doesn't run and the alarm and light go off. When the oil pressure goes up, the oil switch closes and sends 12V to the lift pump (so it runs), and the alarm and light go off. It's complicated, and makes my head hurt every time I look at it and try to remember how it works!!
If your alarm and light are always on, even if the oil pressure is high then either:
-the oil pressure switch has failed, and will not close.
-the connection at the oil pressure switch has fallen off.
-one of the wires is broken or no longer making contact.
Likes: Tom J
Tom J
Sep 30, 2008
2,325
Hi Folks,
Thanks,
Jim
#178 "Polaris"
I had the same issue. Turned out to be a loose wire at the oil pressure switch. My terminals are the push on type, prone to failure. I like Clyde's replacement switch, with screws to attach the terminals.
