replacing mainsail halyard help
3
hunter 25.5 fwb
hi guys, help me please. i have a idea but it may not be correct.
best/easiest way to replace mainsail halyard. thx, paul
Jun 14, 2011
5
S2 27 27 Heber Springs AR
I sewed mine together. I cut the line and pulled the end up them outside the mast through the sheave down the inside of the mast. The turn on the bottom was my point of concern. What ever you do make sure you can back out or the mast will have to be lowered. I did used waxed seizing cord and a needle to sew the lines together. Pull gently and wiggle to assure you are in sheaves.
RichH
Feb 14, 2005
4,773
Sew the joint together using waxed 'sailmakers twine', a triangular shaped sailmakers needle and either a sewing palm or needle nosed pliers. Costs about 15¢ worth or twine.
Oct 9, 2008
121
Marine Trader Sedan Mystic, CT
I have used the same method as Steve with a paper clip and tape for several years and about 6 haliards with no problems. Thanks Steve.
-na -NA Anywhere USA
One thing gents to always remember, when you splice the two lines together to pull the old one out, just keep a minimun amount of pressure so that the attachement smaller line does not come off the sheave; otherwise, it will get caught between mast wall and sheave which will cause some problems.
crazy dave condon
