replacing main sail dutchman system
G
gvs
where can i get lines for dutchman system? and what is a ezay way to install?
C
Carl
Dutchman or sail loft
When we bought our 1987 h40 in 1997 it had fabric Dutchman Control lines. When we replaced the main and got new Dutchman components in 1998, they came with monofiliment line. We got replacement lines from the Dutchman exhibit at the Annapolis boat show. Your local sail loft ought to be able to steer you to Dutchman directly. I suspect you could also buy real high strength mono-filiment fishing line or line for a string trimmer. BTW, when we got the new sail we went from two to three control lines. Our 400+ sq ft sail flakes a lot better with three lines. To install we drop the topping lift, resting the boom on the cabin top. All we need is a #2 Phillips drive screwdriver to open the clamps that hold the crotrol lines to the topping lift. Simply tie an overhand knot in the control line. The knot fits inside the clamp.
K
Karl
Give them a call
The company is still going strong and has great customer service if you call them. If you are not sure what you have or what you need, they will walk you through the proceess to make sure you get the right parts. Martinus Van Breems, Inc. 54 A. Beach Road Norwalk, CT 06855 (203) 838-0375
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
ditto
I replaced ours 2 years ago. Went with two part topping lift...ease of removal. Also bought heaviest duty string trimmer lines avail...they work.
Jul 17, 2006
26
Hunter 376 Sarnia Ontario Canada
Stack Pack
I had the same problem, I went with a Dole Stack Pack. This is the way to go, just drop the sail, then zip it up. Randy
Dec 2, 1999
15,184
I would never trade a Dutchman for a Lazy stack
I would never trade a Dutchman system for a Lazy Jack/Stack Pack system. I currently have a Lazy Jack (non-retractable) system and I find it a total pain in the ass. The top two battens are always getting caught in the jack lines. Contact the Dutchman and have his ship you some new line.
