Replacing Jib Winches
228
Hunter 33_77-83 Cedar Creek Sailing Center, NJ
Sweet deal Rich.... Are they one-speed ?
Two Speed self tailing. I will put them in March, have only one more sail this year before haul-out; frostbite race today. Here are the specs:
Features:
Single-piece bronze center stem and precision machined bronze gears deliver smooth and efficient power
Stainless steel roller bearings housed in a rigid cage
Screw-on cap for fast, convenient access and easy no tool maintenance
Self adjusting springs allow it to handle both today's smaller high-tech diameter ropes and larger Dacron composites
Sleek low friction feeder arm design ensures snag-free operation
Provides a firm gentle grip on the line
Lewmar Winches are great replacements for Barient and Barlow winches
Specifications:
Drum: Chromed Bronze
Speeds: Two
Line Size: 5/16" - 1/2" (8mm-12mm)
Drum Diameter (D): 2-15/16" (74mm)
Base Diameter (B): 5-13/16" (148mm)
Height (H): 6-13/16" (173mm)
Line Entry Height (L): 3-1/8" (79mm)
Gear Ratio: First Speed: 1.9:1, Second Speed: 5.8:1
Power Ratio: First Speed: 13.2:1, Second Speed: 40.2:1
Weight: 14.3 lbs (6.5 kg)
Required Fasteners: 5 x 1/4" (6mm) counter sunk screws
