Battery Choice Concerns
Bang for the buck you can't beat the 6v golf cart. They have good longevity (number of cycles), they're cheap, have a lot of amp-hours, easy to maintain, and easier to lift in and out compared to 4D or 8D (less chance of back injury or damage to the furniture).On the other hand, if the battery box location is not suitable for ventilation, or items would be harmed by corrosive gases, is not spark-free, or your sailing needs should assume a major tilt of the boat (pitchpole, spreaders in the water, etc.), or if the location is not reasonably level, then a gel type battery would be better.We upgraded our H-35 from two group 24s to four golf carts and one start battery in 1983 and the golf carts are still going strong, holding a good voltage (as measured with a Fluke 77 - probably the best tool a boater can buy) and that was 8 years ago. We don't use the boat from end of October until sometime between May and July so this is really hard on the batteries. Ensure they're in an easy place to reach so you can check the water level and add more water when needed.In addition to the other details suggested earlier check the ampacity of the master switch to ensure it can handle the increased amperage. The Perko on our boat had to be changed out to a better Blue Sea switch. It's assumed all the cables are appropriately sized since there was a 4D to begin with, however, with the increased loads this should be checked as the OEM cables may not to be sized to allow for much growth.Reinforcing a previous reply the alternator, regulator, and monitoring equipment is vital for optimum operation and a pleasant coexistence.
