Rehosing 101
Unless you've winterized and the entire system is clean and dry, pump out the tank and run LOTS of fresh water and either white vinegar or C.P. through all the hoses and pumps. And put a big bowl or a bucket under fittings to catch any spills as you take the hoses off. You'll find it to be a lot more pleasant job to work on a clean system than one that isn't...and be a lot happier if you're not chasing odor from spills after the job is done.To remove hose from fittings: loosen hose clamps...warm the hose with a blow dryer or heat gun to expand it. Work it off carefully. If some doofus used pipe dope, silicon, 5200 or anything else except teflon tape, the hose isn't gonna come off..or if it does, it''ll require more effort than it's worth to save the price of a new fitting.. In that case--using a serrated knife--cut the hose off right behind the fitting and replace the fitting. While the system is apart is a good time to put a rebuild kit in the head...replace the impeller in your macerator or a new diaphragm kit in your manual pump. Do it now, and you eliminate the risk of having to take it apart again later to fix what broke or clogged. Getting new hose onto a fitting can be a challenge...especially onto 1.5" fittings. Avoid 1.5" gray pvc plumbing fittings...instead use nylon. Why? Because for some reason all nominal 1.5" thread x 1.5" barbed pvc plumbing ffittings are actualy 1.5" thread x 1 5/8" barbed...a poor fit for a 1.5" ID hose. This problem only pertains to 1.5", and doesn't exist with nylon fittings. Never mix metal fittings with a plastic tank or vice versa...metal and plastic have different thermal coefficients (they expand and contract at different rates) and temperature extremes can crack either the tank or the fitting.Tank fittings are NPT standard...that means they're slightly tapered. Over-tightening will crack a tank, if not immediately, within a few months. Tighten only 1 full turn beyond hand-tight, plus enough to aim an elbow where it needs to go, even if fittings are still showing.If you opt for any hard pipe, don't connect it directly to anything else that's rigid...soft-couple to tanks, toilets, pumps, thru-hulls, using about a foot of hose to act as a shock absorber. and protect connections from stress. Never connect anything rigid directly to anything else that's rigid...iow, don't thread a macerator directly into a tank fitting. Any stress and the weaker of the two will break. If you have to go around a tighter bend than the hose wants to bend, break the hose and put in an inline radius fitting. Do NOT heat the hose to make it soft enough to go around a corner...heat weakens the hose.Use teflon tape ONLY! No other sealant!!!Double clamp all connections. When you're finished, pressure test the system by filling the tank with water, blocking the tank vent and pumping the head till you feel a good bit of resistance. Leave it...check back in a few hours or in the morning. Any leaks will be self evident....and easy to fix by simply using a bit more teflon tape. In extreme cases, a new fitting may be required...fittings aren't made to rocket science tolerances. This ought to keep you from making the worst mistakes...rehosing isn't a fun job in any circumstances, so let's try to get it right the first time.
