Just bought a '93 Hunter 27 in great overall shape and am replacing lines. I've already replaced the main sheet, jib sheets, and vang line with ropes from Knot and Rope Supply in Ohio.
Now, I'm looking at the main and spinnaker halyards, topping lift, and footer. They run inside the mast and boom.
My Bosun's chair is on order since I'm going to have to check the anchor and underway light bulbs which aren't coming on (the only electrical issues).
I've got 18 ga wire to use for re-rigging the lines by running the wire through the length of the mast and boom, forming a loop with the wire to tie a free end of the line to, and pulling the line through.
Bottom to top for the main/spinnaker halyards in the mast and from the masthead to the end (clew?) of the boom.
Will this work? It's my own jury rigging but seems like it could work.
Can someone recommend a better idea without taking down the mast? I presume I should not remove an old line until I've threaded the new one.
If I don't expect to ever use a spinnaker, can I do without a halyard easily enough thus freeing up another cleat?
Thanks for the input.
Old sailor....first boat!
