Replacing freshwater pump on Yanmar 2GMF?
Jan 13, 2009
394
J Boat 92 78 Sandusky
It looks like I need a new freshwater pump on my 2GMF. The signs are there, tearing up belts and the pump pulley wobbles like crazy. Has anyone done the job on their own? How much did it cost if you had it done? BTW, This not the raw water pump which is 1 year old and functioning well.
Jan 4, 2006
7,641
Sounds like something else is going on with the pump. As they age, I would expect only the mechanical seal to fail.
First step is to find out why the pulley wobbles. Maybe prying against it. This is what's chewing up the belt.
Once that's solved, the next step is to remove the old pump and install a new one. You can do it yourself quite easily. Get the Yanmar shop manual or a copy of the SELOC manual for a fraction of what it would cost to have it installed. I would guess the pump is in the neighbourhood of $250.00. Maybe someone has actually purchased one recently and can give an actual figure.
Feb 6, 2009
257
Hunter 40 Camano Island
Closely check the water pump pulley. it may be starting to crack.
the 4 bolts to the pump on mine tore right through the web of my pulley leaving the 4 bolt heads attached to the water pump and the pulley with the new hole loose under the engine.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Pump
I am guessing that you are saying it's not the raw water pump and
really the internal engine fresh water system pump.
Right you did say not the raw water pump,I have never had to change the fresh water pump but some one here maybe has changed one.
Nick
Nov 6, 2006
10,212
I second Rich's comment.. It would be strange to have a pump failure without spraying coolant all over! Loosen the belt and try to wobble the shaft.. IF the shaft wobbles, a new pump will be required:
Category:Engine Parts & Accessories > Yanmar Engines and Parts
Manufacturer: Yanmar
Part Number: 121000-42100
Description:
Cooling Fresh Water Pump Body Assembly
Part #121000-42100 from Yanmar
Note: Does not include mounting gasket 121000-42051
Our price: $144.45 - each
If only the pulley wobbles, check the mounting holes for cracks .. you may be able to simply tighten it.. or if you need a new pulley, it is :
Part Number: 128695-42350
Description:
Fresh water pump V pulley
Part #128695-42350 from Yanmar
Our price: $22.35 - each
These from Toad Marine, your area's distributor.
http://shop.toadmarinesupply.com/marine_diesel_direct/Yanmar/
May 24, 2004
7,213
CC 30 South Florida
Sounds like the pulley itself may have become loose or damaged, I don't think you could miss coolant leaking and the noise that chewed up bearings make.
Jan 4, 2006
7,641
Got to Love ..........................
Description:
........................ your US prices. Probably double that up here.
Jan 13, 2009
394
The noise was noticeable and grew on a 7 hour motor. Coolant is low in the resevoir tank but no evidence of coolant below the engine. Checked pulley and looks ok but wobbles a lot under load with some noise and starts grinding the belt. Tried tightening bolts- no luck. I am having the local diesel guy come this week to replace it. Too critical of an item for me to screw up installing. Engine has not been overheating but then again I haven't run the engine since the problem started.
Thanks for the help
Jan 13, 2009
394
Follow up. It turned out to be the freshwater pump. Had it replaced and the engine works well again. Still waiting on the bill.
