Mike Pilolla
Has anyone replced the fresh water system pump. What brand did you use or would you recommend? I'm willing to spend whatever it takes to have a reliable sytem that will last more than a few months of relatively heavy use. By heavy I mean 2 persons living aboard and taking most daily showers aboard and not conserving water. Unfortunately it seems as if I'm slowly replacing all the small components of most of the ship board systems we have on our new 450. The fresh water pump we currently have is a Jabsco Parmax 2.8GPM pump. It is acting as if the pressure switch is beginning to fail. When we open a tap it takes anywhere from 1 to 15 seconds before the pump starts and while it may not seem like much it does get very frustrating. When we first moved aboard it was easy to keep a constant flow in the shower, but now it cycles very slowly and the water actually stops flowing before the pump catches up with the demand. I also want to try and quiet the pump. It's a bit loud and not well located. Has anyone relocated their pump? What have you done to help reduce the noise? Help.Thanks, Mike Pilolla
